vq35de »
https://forums.nicoclub.com/vq35de-u7384.html
Tue Nov 09, 2004 4:15 am
FI is the most efficient Hp for dollar mod you can make. judging from your quartermile times, you can make the most improvement learning to drive it to its limits.
following that, suspension, brakes (fluid/pads/rotor upgrade not brembo), TIRES, TIRES, TIRES, and flywheel/clutch will make it much faster than any of the mods you listed in your post.
about the only performance mods that are cost effective are a K&N panel filter, the plenum and an exhaust system. the exhaust is iffy but you can get some custom work done cheap that will help a little.
