hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Thu Oct 27, 2005 1:52 am
i bought one of their kits a while back... it had the tiny straight t3 (which is a xs power turbo i believe, but is not stamped with any brand name) .48 exhaust, .42 compressor.
the bov they sent with the kit is a damn 50mm... rediculous.
the wastegate is the same as the boost designs one. spring set at 8 psi.
the kit only consisted of the turbo, bov, wg, and manifold, with all the bolts and stuff... no oil lines or anything. just the main components.
so i saw a compressor map of this turbo a while back plotted with the ka. i can't remember exactly what it looked like, but i know that 8 psi is pretty much as far as you go with this little guy.
i feel like i should write a disclaimer though because of the nature of this stuff. you know, i would never reccommend this stuff as a bullet proof solution. i mean nothing really is a bulletproof solution but for someone that doesn't have the funds to fix the problems that will come this is not the answer. i always have kept in mind that there is the posibility that this stuff will fail and i will end up with a car that doesn't run. between me and my friends though we always have spare cars/bikes/transportation so it would work out fine for me... just make sure if you buy this stuff you have a back up plan. the warranty is all but impossible to actually get ssac to honor i have heard - which makes sense because i tried to ask them simple questions about the spring setting on my wastegate a while ago and they never even got back to the many emails i sent them on something like that.i guess i'm just saying that if you save just enough money for a kit like this and then dump it all on it you will most likely hit a snag and be out of commission for a while, and with no back up car or anything like that you'll be screwed.the kit cost all of $800 shipped. and then i had to get all the other components - which in the end i probably spent $1500 (ic, piping, flanges, couplers, etc) , and then at least another $200 on miscelaneous stuff like gaskets and things on that order - which you will do with any turbo kit.anyway i dont really like advertising and advocating the use of ssac stuff but i mean it has worked for me so i don't want to put people off when it is such a cheap thing that has worked for me.
