Decent Bottom mount Manifold
newdude1
What are some decent bottom mount manifolds that I wont have to worry about cracking on me? I wanna run a Gt28 on it.
And that doesnt cost an arm and a leg
Modified by newdude1 at 4:35 PM 8/29/2008
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Stock cast iron manifold? It's not a pretty manifold, but it does the job pretty well. Cheap too.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
I think the Tomei is pretty reasonable and it included like everything you need.
S14toRPS13
Past threads on nICO points to Full Race or extrude honing the stock manifold.
Neil
Car: shooting laser guns
fwiw i was running a Megan manifold for over a year without incident. I forget why but when I got my GT2871 I put my stock manifold back on. I think maybe i just assumed the megan would crack "any day now", but I kind of wish I had kept it on there. The exhaust note was deeper with it installed.
Megan, OBX, TarboXS, all the "name brand" cheap *** manifold are made by the same few companies in China. I'm sure the Tomei manifold is also licensed out to a cheap taiwanese manufacturer. I've read some threads about the tomei manifolds cracking, too. If the Tomei manifold had a support bracket like the Megan does then I'd consider picking one up because where the pipes collect seems to be a better design than the Megan, and I do miss the sound.
For the quality of craftsmanship and materials you probably can't beat FullRace, but that doesn't exactly fit the "not costing an arm and a leg" category.
edit: apparently the Tomei manifold DOES come with a support bracket. and they still crack?
Modified by Neil at 3:44 AM 8/30/2008
Kalypso
Seishuku wrote:Stock cast iron manifold? It's not a pretty manifold, but it does the job pretty well. Cheap too.
newdude1
Whats involved in extruding and honing the stock manifold?
Neil
I think only a hand full of places extrude hone in the country, if not only one..
The process entails forcing a viscoelastic polymer + an abrasive either back and forth or one way through the passageways of the subject at up to 3000psi.
http://www.extrudehone.com
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Looks like play-doe!
newdude1
well whats the stock manifold good till?
Rosco
Car: 91' SR'ed Hatch
Stock manifold will most likely outlast your turbo and motor. It's Iron. I've never heard of the stock manifold breaking either. I had an OBX manifold and I ended up taking it off and going back to the OEM one. I actually liked the OEM manifold exhaust note better. I could hear the turbo more clearly.
Kalypso
It will last forever, it absorbs heat better, and its simply your friend - focus on the turbo and SS lines. the stocker is fine
Rosco wrote: I actually liked the OEM manifold exhaust note better. I could hear the turbo more clearly.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
newdude1 wrote:well whats the stock manifold good till?
Check out Codyace's build thread. He runs a GT2871 .64 at 22+ psi and 400+ whp. He had his stock exh. mani (redtop) extrude honed and swaincoated (heat coating) and it holds up fine. The stock mani is thick and built right for a bottom mount from the factory.
