OK I'm again looking at my crappy Chilton's wiring diagram and I see you are referring to THE control unit aka ECCS Control Unit - Yes I see at least 2 connections to it - one appears to be shared w/ sensing the fuel pump - probably this ensures the AC and/or condensor fan operate when the engine is running - since obviously the engine continues to run this one may not be a problem but the other connection could be as it appears to control the relays based on the AC switch...
I'm guessing the control unit is located in the passenger footwell area...?
I doubt the connection at the control unit is a problem as these usually have a large loom w/ a snug multi-connector but will check. It will also be a good place to do further debugging IF I can ever induce an intermittent problem.
I also found a SECOND wiring diagram covering the AC within the same crappy Chilton's book. In the first it looked like the FICD Solenoid was wired in parallel so I dismissed that circuit. In the new diag it looks to be wired in series - that could suggest the FICD Solenoid might be a possible 'hold up' to the compressor if simething is not working correctly there... it's another potential failure point to eliminate at the least. I presume the FICD is some sort of idle compensator for the AC?
Whether it's in series or parallel to the primary AC relay, I CANNOT find the second AC mystery relay whatsoever...
And which wiring diag is correct I dunno...
...and it gets worse - Not only does Chilton not bother to provide a single consistent diagram they dont' even PROVIDE WIRE COLORS!!! How's that for fun?
I'm sorely tempted to wire my own independent AC on/off switch directly to the relay - but before I do that I also need to verify if the condenser fan is cutting off w/ the compressor...
Well I need to go study the second ECCS wiring diag and try to make a judgment as to which if either is accurate.
