r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Wed Aug 22, 2007 7:58 pm
Ok, the real problem with the stock CA revving high is that the rod bolts are relatively weak and will stretch with repeated 8k rpm shifts, resulting in spun bearings. I see no problem with 400hp as long as you strengthen the bolts in the bottom end and built the top end to make power that high. In stock trim the CA wont make power much past 6500-6800rpm, but you really dont care about that do you? some 272 cams with a 9mm lift and a big turbo ought to suit you well, and some forged pistons and perhaps some shot peened and/or cryo treated rods with ARP (or similar) bolts should cover it. If you cover your bases properly, you should be able to rev this little engine to the moon repeatedly with no trouble.
p.s. im drunk.
