Always interested in a project. I'll ahve to go to the yard to see if there are any good motors around.captainzeros wrote:There is always the option of slapping an L20B head on your old Z24 block and hybridizing the thing for the easy of the bottom end all being the same for some performance increase (and the fun of doing a project, if you're into that)
Article here: how-to-put-an-l-series-head-on-a-z-block-t469981.html
Have to admit I'm not well educated in the KA engines, so I'll need to do a lot of research before I even pick a motor. This will be a somewhat long build thread if I go that route.flinterman2000 wrote:Do a swap. Which one would be according to your pocket. The KA is easier and cheaper and somewhat more reliable than the Z24. If you have time, then it won't hurt your pocket that much. I'm waiting to hear the results.
Looking to do the same swap that you did, including the megasquirt. How did you know which KA engine to use, additionally, what year models are they in?noface wrote:I say swap to a KA motor from a hardbody. Much better engine, more power and torque, and can be done rather easily. And no carburetor when you're done...
If you decide to rebuild yours, take it to a shop that's got a good reputation locally. Let them do the rebuild of the internals, especially if you've never done it and don't have the tools and facility to do it RIGHT. Do it half-a$$, and that's what you''ll get.
I suggest the swap since I rebuilt the head and surfaced the block on mine. Great little motor, but it still would blow head gasket after a couple months... I think its a pronounced weak spot with these motors, which is why I suggest the KA.
