debadging? help!?
vi3t89
Car: NISSAN ALTIMA 2.5s
hey... im not sure if this is a repost but i was wondering if anyone in this forum has removed the altima badge and the 2.5s or 3.5se badge on the trunk of their car? if so i was wondering how to remove the emblems and if their would be any holes on the back? thanks ...
jak0
Car: 2008 Azure Blue Altima Coupe
Hey,No there are no holes behind the emblems. If you use a blow dryer and heat the emblems, you can easily take them off by slipping it out using dental floss. Just blow dry and carefully work around the edges and you should have no problem. Good Luck!
generic808
Car: '08 Infiniti G35 S
'10 Infiniti EX35
EDIT: ^ I guess we posted at the same time.
Nope, no holes. It's very simple. Just use a hair dryer to heat up the area and use dental floss to slowly wedge between the body and emblem. You can use a sawing motion to help ease it in there. Then slowly pull it outward and that's it. You'll have residue left over on your body which can be removed by using a lot of rubbing with your fingers and a lot of elbow grease. Or you could use certain chemicals--Sticky Out by Elmers worked good for me without leaving any paint fading or damage. Always remember to wax the area after you're done.
According to some members, Goo Gone seems to leave some paint fading so beware with that product.
vi3t89
thanks for the help guys maybe i should wait til the snow melts its pretty cold over here
Vet Boots
Car: 2008 Altama Coupe 3.5 SE
I didn't even use the Blowdryer to get mine off or dental floss although I might have tried that if I'd known about it. I used a plastic spatula (the kind for flipin egg etc. on a teflon pan. I just pushed it right under and it came right off. It's held on with dubble faced foam tape. Use peanut butter to remove the residue and wax it afterwards. Works perfectly.........
Deke40
Car: 07 Nissan Versa SL HB 08
I am not going to debadge but am having my entire trunk lid repainted due to a scratch on it when I bought it. Had seriously entertained the thought of having them order the 2.5 emblems instead of the 3.5s. Would be fun to mess with people's minds and have them wonder what mods I had that would make a 2.5 run like a 3.5.
spike228
Car: 2006 Nissan Altima S 2.5
I used Goo Gone when I dabadged my car. I haven't had any paint fading issues. I went over the area with some detailer and cleaner wax right after getting all of the sticky residue off.
I would recommend doing the same if goo gone is used.
theanswer
Car: 08 altima coupe 2.5s, radiant silver
i live in south florida.. so didn't have to heat up the emblems. i just used dental floss and it came right out, then i was left with the sticker/sticky residue which peeled right off
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
peanut butter really?
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
fishing line works too. WD40 takes off the leftovers, just wash/rinse with water, and no more badges!
spike228
Dental floss is much more effectively than fishing line. Trust me...I've done it both ways and I definitely feel like I wasted a life time using the fishing line.
prlwhitecoupe
Car: 2008 Pearl White Altima Coupe 2.5 S w/CVT & Premium Pkg.
Used a hair dryer and heated up the emblems, and the double sided tape got soft and i just started peeling the emblem from top to bottom slowly...didn't even need the floss..although i had it just incase...worked out real well...but sometimes i contiplate if i should've just left it...i like having mods but still have the car look as close to factory as possible..not so in your face modded....know what i mean?
PJPrunesti
I would recommend that you stay away strong adhesive removers such as goo-gone and goof-off which is the alternative to goo-gone that supposively replacing it on the market. Because yes it can fade the paint depending on how much you use and how long you let it sit for, but even if it doesnt show signs of fading then you still have a strong chance that it is dulling the paint or making it weaker, so in the long run it can affect the paints condition. I have never heard of the peanut butter solution but that is something to try, but when i debaged my altima i used fishing line, wd40, and 3m wax results were great but either way be carefull around the paint.
cfrank467
Car: nissan altima coupe 08
Idk why people would wanna debadge their car personally in my opinion debading your car will make it look plain unless its some old 1995 honda civic ... thts just my opinion what do u guys think
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
you know how some ppl like to "rice-out" their ride by putting all kinds of emblems such as R, turbo, supercharged when they don't even have those things on there. There are ppl who just wanted a clean look
Deke40
cfrank467 wrote:Idk why people would wanna debadge their car personally in my opinion debading your car will make it look plain unless its some old 1995 honda civic ... thts just my opinion what do u guys think
I had to have my trunk lid painted because of a scratch a delivery. I had the shop foreman leave the badges off and stored them in the turnk.
I have had numerous people tell me how clean and appealing it looked without the badges. Even the sales manager commented on it.
Also gives you the ? factor when you blow the doors off a 2.5 or other make.
JLAUDIO85
Car: 08 Black Altima Coupe 2.5SL CVT.
you think...i could use peanut butter and jelly??mmmm time for a sandwich lol
BatmansDreamCar03
Car: 2008 Nissan Altima Coupe 2.5
how do you get a blowdryer to your car ???
johnny_d
ever heard of extension cords?
Mr_Coupe
Car: 08 Code Red 6 speed manual transmission 3.5 v6 Altima Coupe
why dont you just use turtle wax its cleaner and easier any wax really
SkunkWorks
Car: R32-4 Skyline GTS-T Sedan
Unless you hamfist/splurge or your paint quality sucks, Goo Gone should not fade your paint.
vi3t89
hm im just ganna debadge n bring it to a car wash/wax shop to let them take care of it .. hard to wax a car when its freezing cold winter outside
MikeisSUPERBAD
Car: 2011 Nissan Sentra SE-R
thanks guys! the dental floss worked perfectly.im in NY and its about 44 degrees here and didnt need to heat it up with a blow dryer.. came right off with the floss. i used turtle wax bug remover to clean it up nice.
D-Roll
Car: 08 Nissan 350Z Touring Coupe
Just did mine, used dental floss and only took 5 mins
niztec
Car: 2008 AlTIMA COUPE
floss is the way to go especially if the car is new. it would be easier to take off
rj alty 07
Car: 2007 3.5 SL Full Tech Package ,20's, 6k hid, fujita SRIntake,
Debadged using floss and a heat gun.
team_work
Car: 2006 G35 coupe
how bout debadging and adding these...
dj figz
Car: 2011 g25x, 2007 jeep srt-8, 2010 maxima sport w/monitor package,07 altima 2.5s superblack
i used fishing string. then used 3m car adhesive remover then i waxed it. not one scratch.
