WesQ »
https://forums.nicoclub.com/wesq-u84390.html
Sat May 15, 2010 11:06 am
Yes, an interesting question. I asked David D how specifically an injector with bad varnish fails. He didn’t really know nor did he get any details from the Nissan engineers. So I can only guess at possible failure mechanisms. As the varnish deteriorates, the coil windings will eventually short. If voltage is constant, current draw will quickly increase as resistance drops. Since, heat is proportional to the square of the current, even a small increase in current can cause heat to build faster than the coil can dissipate it. In addition, shorting will disrupt the magnetic field affecting the ability of the injector to meter gas. As I understand, the ECM will adjust pulse width for that bank of injectors in an attempt to maintain proper air/fuel ratio, which will add more heat the failing injector. If the heat is high and local enough, it could burn out the coil windings resulting in an infinite resistance when measured with an ohm meter. However, that does not explain cases where resistance gradually increases. My #1 injector was electrically open, but #7 measured 149ohms. So, in some cases, maybe the shorting and resultant increase in heat is not high or local enough to burn out the coil, but enough to ‘cook’ the coil and its internal connections over time. The high temp cooking may gradually oxidize or semi-open the junction/connector between the end of the coil wire and the injector’s harness connectors leading to an increase in resistance. Anyway, this is all supposition. We should get a 6-pack and take a few failed injectors apart.
