Dr1fterXL »
https://forums.nicoclub.com/dr1fterxl-u34559.html
Fri Nov 18, 2005 12:11 pm
When i bought my 240 it was a recovered stolen car, it had a box in the back of weird parts mixed around in it ,including injectors. Well the time has come where i have a HUGE enrichment problem i mean to where my car wont run for more then 10 sec. before flooding. I took my fuel rail off and i noticed only 2 of the injectors were the same! lol.Well i took it to napa and they said many things could be causing this enrichment including a failing FPR, the MAF sensor ground could be coroded, or fuel could be leaking past the injectors directly into the manafold by dried out o-rings. Ive decided to buy new performance injectors from deatschwerks becuase im planning to go KA-T anyways so i might as well address the fuel now. Im looking at there 480cc set becuase there not to much more then 4 OEM replacments from checkers.. Anyways my Q is are there any issues that i need to address with a injector size like this without a fuel pump/ or tuning? I know new injectors wont fix my rich problem it will just make it worse, but i tested my FPR and it was stuck.. so i will replace that as well. Anyone try this injector size without any tuning, will the stock ECU correct itself enough to run good enough? thx for all your support because i need to get this peace back on the road soon
