Death Rattle
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
clayton bigsby
Car: 82 Datsun King Cab 4x4
Hello there. I have an 82 king cab that vibrates loudly one i hit 65mph it doesnt seem to effect the power or handling, just a loud vibration. I thought it sounded like the engine until someone said it could be the rear ball joints. now, normally i would investigate that, but another guy with the same truck was having the same issue. Just wondering if others have had it and/or advice on a solution. sorry- small engine guy here, new to the game.
thanks
themadscientist
No steering wheel wiggle?
clayton bigsby
no steering wheel wiggle. everything is pretty normal except how crazy loud it gets
xsdg
Car: 1985 Datsun 720
Rear ball joints? There aren't any ball joints on the rear, are there?
How big of a speed range does it happen at? Do you see any feathering or shark teeth on the insides of your rear tires? Does the sound seem like it's coming from any particular direction, and/or can you feel any buzzing with any part of your body?
I know that in my truck, the rear window will pick up a resonance sometimes, so maybe try pushing your fist against the rear window while it's happening.
clayton bigsby
its a vibration noise at 65mph and up. nothing in the cab is actually vibrating. tires are ok
Return to “Datsun 720”
