here are some pics...i think it looks horrible!SHIFT_COUPE wrote:Snap some pictures. I could probably give you a better answer. Typically if you have condensation in your exhaust pipes due to more frequent short trips this would cause what your seeing. Also, are these tips chrome? Does it wipe off? If so, this is fairly normal.
Sounds like a good solution. May take up some time but should fix your problem.Infinite-T wrote:Borla makes exaust pollish to clean up your tips. On the pipes under the car, might be a bit harder, but it may work there too. Get some brass wool (instead of steel) from a hardware store or online. Brass is softer that the steel so it wont scratch it. Use the wool and the polish and it rubs right off and looks great, at least it does on stainless steel.
thanks for the heads up. i'm ordering it now!Infinite-T wrote:Borla makes exaust pollish to clean up your tips. On the pipes under the car, might be a bit harder, but it may work there too. Get some brass wool (instead of steel) from a hardware store or online. Brass is softer that the steel so it wont scratch it. Use the wool and the polish and it rubs right off and looks great, at least it does on stainless steel.
