ddgsxr504 »
https://forums.nicoclub.com/ddgsxr504-u24314.html
Sun Mar 02, 2014 9:13 am
So I have a 2011 R51 Nissan Pathfinder Silver Edition with 35,000 miles. I recently towed my S14 from LA to SD when the clutch fork went out and it pulled her fine but I've noticed that it suffers on hills and shifting transmission wise so I was like yea… I need to change the fluid plus it says so in the owners manual.
However my schedule has been pretty full and I haven't had the time to do a drain and fill myself and I needed to bring the Pathy in to get the passenger door handle looked at before the warranty was up because the little cap that covers the non-existent key lock broke off. (Turns out the whole handle is faulty), anyway… Since I was taking it in for that I figured I'd just let them do the drain and fill. 5 or so QTS, shouldn't be that hard, what could go wrong. I drop it off at 9:45am yesterday morning expecting it to take a good 4+ hours. I called back 6 hours later and it was JUST getting put in the bay for the drain and fill. They did diagnose the door handle and claimed that's what took so long. The actually D/F took about 30min. Since they made me wait all day I decided to let the shuttle come get me (wife followed me in the morning). Upon getting the invoice I noticed that they listed the fluid they put in the transmission as MATIC-K.
I have a photographic memory of sorts and I skimmed thru the owners manual a couple of years ago so seeing MATIC-K on the invoice caught my eye but didn't set off any alarms. It did bug me enough to do some research when I got home. Sure enough the owners manual calls for MATIC-S which superceeds MATIC-J Fluid. Turns out MATIC-K is for FRONT WHEEL DRIVE 5 speed transmissions.
So, my question is obviously they put the wrong s*** in. How harmful is K to a RWD transmission? I fully intend to get a flush and refill (FOR FREE). I know that some might say that it's probably the same s*** and I shouldn't worry but if NISSAN makes two different kinds then why would that be true? You had one f*cking job Nissan. SMH.
