DELUNASC wrote:What is the trunk strut problem? Is the trunk suppose to fully open by itself when you hit the button, or only slightly open?
Pops open only slightly. Should be about 1 to 4 inches ... give or take a few ... due to the springs. On my repaired ones (Infiniti warranty fix), it goes up about 6 inches or so.
DELUNASC wrote:If it is suppose to fully open, I will need to fix mine as well.
No need to fix as long as it does pop up a bit and stay up without retracting and closing again (this is the common failure). However, if you want a fully opening trunk lid, check out Jason Burtman's system that he sells for that generation of M45:
http://www.burtmanindustries.com.
Z
