This is a pretty straight forward procedure.....but I caution from trying this the first time on your only set of wheels. I have seen many of these 3.0s come in on a hook with a no start after timing belt replacement, or died while driving. I hate to find something loose or missing or a belt off cause irreperable damage. Sadly no one has ever been more interested in seeing if it was complete destruction or not, the check out time is not worth it to many.
You can find anyone to fix you J but take it from someone who fixes all Infinitis for a living, the J is something many of my co-workers don't want to work on. It is not an easy car to diagnose and is overly complex in many regards.
Remember you have a dual overhead cam timing belt controlled engine. One wrong tooth on any of the cams improper setting procedure and your motor may be toast. At least if the shop blows it up they should be on the hook for it.
Ebbtide wrote:I would change the belts, bypass the knock sensor (if it really is not working), and drive it into the ground. It might takes years to do that. I would then get a used G35 with the money saved.
With a car that age you could spend that 6000.00 bucks and a week later blow the transmission, ac compressor, cats, or any number of things.
I love the J30, best daily driver I ever owned, but like a sick dog, sometimes it's just better to put her down. Or you can sell it before it loses all its value.
I know this post is a downer, sorry.
Getting the parts for a good deal and having someone who has never worked on a J is a waste of money and you have a better chance just saving your money and doing it right once. Trust me.
In the several months of J daily driving I really love the car and from the inside seems like a simple enough car but there is a surprising amount of wiring and control units that talk to each other and engine control feature that were ahead of their time are common on this model. Treat it with a little love and it will return the favor. I have been stockpiling OE parts as I come across extra cash. The parts are expensive but they worked for this long without replacement, they are worth the investment...welll within reason.
