Dealer says I need a new timing chain at 53k???
TomD88
Car: 2005 Infiniti G35 Coupe
I brought my 2005 Xterra SE in to the dealer the other day for some recalls. Next day they call me and tell me that there is a slight squeek in the motor (that I had never here in my life before) and that the timing chain needs to be replaced. The truck only has 53k on it so I am thinking he is full of it. When I get to the dealer he clues me in on the tiny squeal or sound the chain is making. He diagnoses it as the timing chain guide being worn down and the whole timing chain thing needs to be replaced before the whole car brakes down.
How urgent is this problem really? My car is out of warranty by 5 months so I really don't want to go to the dealer if I don't have too? How much should I expect to pay for a new timing chain?
Thanks
Hooked on 240
TomD88 wrote: How much should I expect to pay for a new timing chain?
Thanks
From a dealer? LOL idk how to answer that without telling you to take out a personal loan.
Id get a second opinion from a local garage or 2. Dealership told me my 240 my rear pads needed to be replaced. i had hawk ceramics, and they squeal bc there ceramic. lol Sometimes dealership just get money outta ppl
RT22
Car: 1991 nissan hardbody
If the guides are worn it will rattle on first cold start up. Let it sit over night open hood and crank it up. if guide needs replacing it will rattle on start up until oil pressure builds. 53k seems real fast for timing chain issues they usually go 100k plus before needing guides. if it is quite at start up then drive NOW and while engine is still not fully warm go through the gears with window down and radio off and listen for rattle. My hardbody rattles on start up and above 2 grand rpm until warm
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I thought the X's ran belts. :donno
KA24ET_D21
Car: 1991 nissan D21 hardbody
KA24E
Reverend D21 wrote:I thought the X's ran belts. :donno
Some of the x's had Duel cam KA24's in them.
TomD88
So, I brought my rig into an independent, who told me that the guides are beginning to ware down some but there is now immediate threat. He said once the rattle begins, like RT22 said, and there is a high pitch squeal then come see them. Plus, he was going to be $500 less than the dealer. I swear that the recalls are just to get you in to give them an opportunity to up sell you on other things.
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
And if that engine is like the KA24E it will wear thru the back of the timing chain cover.
Right behind the water pump, thus filling the oil with coolant.
mdawg4x4
Car: 2006 Nissan Frontier NISMO CC 4X4
2011 Nissan Murano
2006 Nissan Sentra
1963 Nissan Patrol
I just spent $1800 to have mine fixed, but I went ahead and had the water pump, idler pulley, belts, and plugs all changed, plus an oil leak fixed from behind the rear timing chain cover that was there when it was new that the dealers never could find.
