casperfun wrote:Because later he states that after filling the oil himself, he then states it was now almost filled. I don't think he would feel shortchange if he was getting 5 quarts. Just a misundestanding of the facts folks.
No, rogueagent08 stated he put 6 quarts of oil in... that's more than
1 full quart over the Rogue's 4-7/8 US qt capacity:
rogueagent08 wrote:I removed all the rings and filled the oil with 6 quarts of Castrol 5w-30 and removed all those rings and put back 1 crush washer.
I have performed at least 50 oil changes on this motor.. my Altima and Rogue combined. I usually put in almost 5 quarts (4.75l) of oil on every change. I start the motor and let it run, shut it off, wait 10 minutes and it's bang on the full mark.
I strongly suggest rogueagent08 check the oil level. Overfilling a motor is just as dangerous as running low on oil. The reduced noise he's hearing could be due to excessive oil in the crankcase... the crank is now flinging way more oil around than it was ever intended to. Worse case, he could hydro-lock the motor... oil does not compress... engine parts will break first.
