Dealer can't find part #
420sxse
Car: 92 s13se coupe
92 240: I need the part numbers for 2 of the 3 hose segments included in the coolant run from the firewall to a metal pipe through the underside of the intake collector to a 6" piece of straight hose to a second metal pipe to a third piece of hose that runs into the side of the thermostat housing. Direction of flow is from the heater to the thermostat housing. (heater under dash->hose(with loop?)->fitting in firewall->>>>1:hose->pipe through underside of the intake collector->6'' hose->pipe along underside of collector->>>>2:3rd hose segment->thermostat housing ). In the diagram on page LC10 of the FSM the first piece I need attaches where the arrow by the words "From heater pipe" is pointing. The 6" piece is also clearly visible, and the other segment I need is behind the word "head" in "To cylinder head". I tried ordering these three hoses from a dealer and they sent me the wrong ones (except the 6" piece in the middle. It is part #21308-05E01). This was a Nissan-only dealership I live far from. I went to a closer dealership that does Toyota, Nissan, and GM; but we couldn't find the part listed anywhere. They were using ProQuest Automotive EPC software to look up parts. Sorry for the long description. I would greatly appreciate any help.
420sxse
Car: 92 s13se coupe
Please, can no-one help with this? I went to Napa to see if there was something I could make do with, but the first one has an "s" bend. I don't want to jury-rig something that will kink. The bit that hooks into the side of the thermostat housing just has a 45 degree bend, I am sure I can make do with something, but the bit coming from the firewall tore when I disconnected it. Is this a part that has been discontinued like some of the secondary air lines?
addendum: the heater hose I am talking about is 16mm inside diameter.
zer0c123
Car: 1993 Nissan 240SX Hatch
try this site
http://carfiche.com/fiche008/
It's kinda hard to use, but you'll get the hang of it.
or maybe mike from midway nissan can help you with this.
420sxse
Car: 92 s13se coupe
That is a flippin sweet site! Thanks. I found one of the hoses on page 2-j9. It is part #14056-53f01 (14056p in the diagram). The one the dealership got right is 14056n on the diagram. SO, my next question is: on page 3-e8 is part 92410 on the diagram behind the firewall or in the engine bay? I'm thinking that may be it, but the one shown might be for the ka24e, while the part for my ka24de is not shown but listed on 3-e8 as 94210-53f01. Diagram: hose has a loop. On my engine: hose has an "s" curve along a single plane.Thanks again zer0c123!
