szh »
https://forums.nicoclub.com/szh-u149.html
Tue Oct 07, 2008 9:05 am
Exactly the reason why I stick with OEM pads ... and recommend doing the same to everybody here.
Changing the rotors to a non-OEM brand is okay though, as long as the weight (i.e., the Iron density) is as good or better than OEM. The weight of the rotor is important because too low a weight/density will not be able to provide the heat capacity needed to remove heat from the pads, etc., during braking.
Z
