Dealer Badge
GJEMD
I have a dealer Badge on the trunk lid I want to remove. What is the proper technique?It appears to be an adhesive backed badge.
HolySh*t
Car: 2003 Infiniti M45
If it's adhesive, floss. Then buff out any residue.
Andrew224
Car: 2001 Infiniti QX4
2006 Maserati GranSport
2002 Harley Davidson VRod
It might help to heat it up a bit to make it easier to get through the adhesive (i.e. a hair dryer) and carefully pull it off. I've never used floss, but I can see how it could work. As for the reamining adhesive... I've used a small amount of Goo-Gone and then washed the area off (I don't think leaving Goo-Gone on the paint for longer than necessary would be good, although I've never had any problems).
Andrew
jgoodman
Car: 2006 Infiniti M35X
If you use a goo remover, make absolutely sure you are not using a product that removes oil-based paints. Do NOT use Goof-Off. There are 2 types and one will remove your paint.
lfj2025
Car: 2003 Infiniti M45 Black on Black & 2000 Mustang GT convert
I have always used WD-40 to remove whats left after pulling the sticker / badge off. Hair dryer works great.
