911/Q45 »
https://forums.nicoclub.com/911-q45-u148.html
Tue Sep 16, 2003 11:22 am
Your plastic regulator has failed. It's the part that connects the motor to the window. It's been a while since I bought one, maybe $100. Labor could be tough if you don't DIY. Remove the door panel and speaker and you can work through the holes to R&R the piece. Mark the position of the slotted bolts to reduce alignment problems.
