Dead Pedal broken
digitalis46613
Car: 2008 Nissan Rogue SL
My 2008 Rogue SV has a broken dead pedal styrofoam insert and the carpet is mangled from being crushed for so long. Any advice on anything I can do to fix it? I removed all the tiny crushed styrofoam under-support that was in the hole and stacked it with layers of thin rubber mat for now. It's better, but I'm thinking 1" thick foam board, cut, shaved and glued in place to fit in like a puzzle, for the structure. As for the carpet, I have less options. It's ripped all around the place it broke, so I can tape it together, or I can just leave it ripped and cover it up with a high-priced Weathertech mat the covers the whole dead pedal area for further protection.
Any advice or other ideas?
kboo74
Car: 2015 Nissan Rogue SL AWD Premium Pkg (Former)
2017.5 Nissan Murano SL Tech Pkg) (Former)
2019 Acura RDX A-Spec with Tech Pkg Performance Red
I would go the Weather Tech route for better protection. Trying to match and price together carpet is going to be a pain to do.
Ken
digitalis46613
Weathertech doesn’t even cover the pedal area. I found a mat on amazon and eBay that does. My question is less about protection and more about repair though.
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
Try the junkyard you might be able to find everything you need including matching carpet. Just cut most of the driver floor pan carpet out and piece it in your vehicle where needed. If you’re really lucky you’ll find weathertech floor mats.
Slumpert
Car: 1997.4 Pathfinder
kinda shaped like one of those oversized door wedges.. Get a rubber one and trim it might be a option.
Return to “Rogue Forum”
