dse0001 »
https://forums.nicoclub.com/dse0001-u214967.html
Tue Apr 23, 2013 9:15 pm
Well, it looks like I have a fuel problem. I thought the pump was okay as I used it to drain the year old gas, but it doesn't seem to have enough pressure/volume to fuel the car. I say this because after cleaning contacts and testing, the car still wasn't running. We went and bought some ether (what would Hunter Thompson do?) and got the car to fire on that.
When I drained the fuel, I disconnected the line under the hood and ran it into a gas can. I never got what could be called a strong stream. It would flow for about four seconds, stop and then I would reset the circuit. I understand the time limit is normal, but I'm not sure about the volume.
Has anyone out there pumped gas as I've described and if so, did it spray with good force?
I don't have a fuel pressure gauge, but I might buy/borrow one.
