DEAD ENGINE?! -- HELLLLLPP.
ninetysevenI30
hello everyone.
long story short -- been driving my 97 i30 fine with no problems (except for the oil leak that ive posted awhile back).
i went to the store to purchase some things (20 mins drive out / 20 mins drive back).
car was running fine.. no problem. everything was RUNNING NORMAL -- about 2 stop lights away from home.. THE CAR STARTS SMOKING/ALL POWER DEAD/ rolled it downhill in neutral to the nearest parking spot.
only way to get it home was to get it towed.... engine has no COMPRESSION.. doesnt even crank.
*coolant in between max/min level // oil was definitely in there before i left (i check it before i leave-- due to oil leak)
how could this happen out of nowhere?!! -- from perfectly fine -- THEN DEAD in 40 mins of driving...
is it time for a new engine? // engine work? -- NEW USED CAR?!
ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
would really appreciate some input.
thanks in advance.
maxhopper
Car: 02 Maxima SE 6spd
Sounds like the engine may have seized. I'd remove the spark plugs and try to crank it. If it still won't turn over, try to turn the crank using a breaker bar.
You could probably find a decently low mileage engine through www.car-part.com or www.lkqcorp.com.
