Dead end off the intake...
Dattebayo
OK. You folks who have the fsm, there is about a 1 inch ID hose coming from the bend in the intake right before the throttle body. Does this thing have any function? It seems to dead end into some plastic round box mounted on the rear of the radiator. If there is no function (or one that matters) i can remove it, right?
JJ240
Car: 95 white 240
yeah just take a look at it. Its just a resonator. which means its junk
themadscientist
if you remove it you might notice some hesitation at throttle activation but that's it.
Xero
^^really? hmmm...I know I removed it, but what is it's specific use if it causes hesitation?
themadscientist
If it's what I am thinking it is you will reduce the amount of filtered air available when you nail the throttle. It takes a second to get the air flowing in at first when you jump on the gas suddenly and when I have removed these types of resorviors I noticed a slight lag when the throttle was nailed that wasn't there with it in place.
Xero
but it's a sealed box, how can air come out of it, I was under the impression that sound goes into that box, and is then made quieter, but that's me.
themadscientist
it's a box attached to your intake pipe to store filtered air. with it gone and the intake pipe resealed the volume inside the intake will be lower.
NeedCAforS13
Car: CA swapped S13 coupe
are you two at it again? i thought we decided that themadscientist was NICO's mad scientist! silly Xero!:D
Sean
Xero
^^lol!! but when I took it out, it was just a box, exactly the same as the one over under the airbox, which wasn't used for anything, I don't understand how a sealed box could hold air when it's solid plastic and it would have to expand and contract with the differing pressures,
singlecamhonduhkilla
Car: learning all i can about this car.. some street racing.. etc..
themadscientist wrote:If it's what I am thinking it is you will reduce the amount of filtered air available when you nail the throttle. It takes a second to get the air flowing in at first when you jump on the gas suddenly and when I have removed these types of resorviors I noticed a slight lag when the throttle was nailed that wasn't there with it in place.
that makes alot of sense to me.. its just a reservoir.. when the normal use of the airflow comes in.. when ur on the gas.. it saves some in the boxes.. so when u decide to slam on the gas it takes the reserved air from there plus the suction of the filter.. not much saved air though.. but still..loljoe
themadscientist
Of course it can't hold as much hot air as yours truly!:D
jrc90240sx
?? man i am lost on this one. if you where to have a box that had only one way into it. if you where to pull air out of it, it would have to get air from the same place your taking it from eliminating any use for it to suply air to your engine. know if it had some sort of bypass so it would not create a vacum in itself then i could see its ablitly to provide more air.
jrc90240sx
but what do i know
Neona
Car: i fling poo
*high5* jrc! THAT.. and.. one sec, tom's gonna post .. *ftaps*
Xero
here, have an artists rendition of what I believe happens :D
JJ240
Car: 95 white 240
the resonator is vacuum locked. It wont release air without air coming into it from somewhere. Most likely when you open your throttle the air in that resonator wont even move. It will pull air past it from the intake. Removing the resonator in this case shouldnt do anything.
Dattebayo
its hard to believe my little question started a war. I'm gonna take it out tonight, and ill post if there is any noticeable hesitation.
trpower7
I took mine out, plugged the hole, nothing happened. Doesn't affect a darned thing.
Dattebayo
well i just thought there would be a more direct path to the throttle body and no turbulence. I wonder what its called in the FSM. HINT HINT besides no matter how stupid it is it should have some kind of function. Would you through extra crap into an engine if you were an engineer? NO but what do i know
TomsMR2
Car: cars.. etc
2BN_S13 wrote: Would you through extra crap into an engine if you were an engineer? NO but what do i know
yes. same reason they stick 1 7/8 exhaust pipes, a million foot long intakes, and soggy suspensions on cars.. its more comfortable.
those are resonators, it keeps the intake quiet. companies would be criticised if they sold obnoxiously loud cars.
the reason some of you are having a laggy feeling is because you have longass large diameter intake pipes. shorten the intake pipe and the lag goes away.
Xero
it is designed to decrease the sound of a car, therefor it has a purpose. Old ladies that buy cars feel that there shouldn't be too much noise, therefor, they decrease noise as much as possible, as a general rule for ALL cars, so they don't keep coming into the shop, or they even buy the car in the first place
TomsMR2
Car: cars.. etc
ok it serves a purpose.. just not a performance oriented one ;)
trpower7
Yep. And engineers re-think and re-work things all the time, such as the AIV elimination on late model S14s, etc. Engineers have to crank cars out QUICK, and sometimes it's cheaper and more effective to play it safe than lab and shop time testing it.
corn322
Car: 1993 240sx
xero, that was a very nice picture. paintbrush? :) always remember, if it's stupid and it works, it's not stupid.
TomsMR2
Car: cars.. etc
the purpose its "working" for matters tho..
the THREE cats on the WRX "work".. but they still suck ;)
resonator boxes work.. they resonate and cancel out sound.. but they definately suck ;)
Xero
I thought we all agreed that they DON'T suck :D nor do they blow, so what use are they :D
yes, that pic was in photoshop, I felt like being a **** and making an illustration, I've got mad tizzight drawing skillz yo!! :D
