Soravia »
https://forums.nicoclub.com/soravia-u34591.html
Fri Mar 16, 2007 12:42 pm
Hi, My S-13 '91 manual (Build date) just got its engine, transmission, harness & ECU swapped into another '91 manual. I finally got the engine started but none of the electronics except starter, head-light & Hi-Beam (and its icon on cluster) are working. No CD, (I took that off later) no signal, no fan/ac.The wiring I have yet to complete on my car are-Wind-shield water pump-Emission unit next to exhaust (I took it off)-A/C compressor and tube next to battery- The little long piece bolted next to the ignition coil on that model.-One white and one black piece of plug near the fuse box on the driver side (There is no place to plug them. Mine is base model on both cars, is that why?)
Is my ECU the cause because both clusters I have are acting the same. Only the Hi-Beam comes up when I use the Hi-Beam. When I last saw that ECU, it was working even after I crashed the car, playing the CD and all. If I accidently swapped in a SR20DE or S-14 ECU, would it be the cause?Should I try plugging in an ECU from an Automatic '91 to see if it's the ECU before I go out and buy one for $50. My car engine runs and fuel pump works but I want to fix the cluster before I go further.
Thanks
Modified by Soravia at 10:03 PM 3/16/2007
