dead cylinder
BabaGenushe
Car: 1992 Nissan 240sx fastback...1972 Plymouth Satellite, 440
ok so i have a 92 fastback and i cylinder 3 is dead. so far ive switched the spark plug and checked spark, changed the injector and checked to make sure its working. still dead.... i dont think its the maf since the car runs the other three cylinders fine. havent pulled the valve cover yet but did a comp test and got 120. im not really sure what the hell is goin on im asuming no bent valve cuz i have compression.. fried computer maybe? vacum lines look good timing was ok... i dunno i need the nico gods on this one...
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
well...i have had a few issues with ecu's not firing injectors before...but not spark...so test that cas sensor inside the dizzy first...second...ohm out your plug wires..or switch one that you know is good and see if #3 fires then......do the normal "check grounds" routine...if those check out fine...find a friend with another ECU..drop it in and see if it fires..hope this gets ya going in the rite direction.
BabaGenushe
coll man thanks for the input im gunna try a few things in the morning and kkep postin. i hate to sound newbish but cas is the cam angle sensor? and dizzy? lost you on that one sorry
Razi
Car: Moo
CAS = Crank Angle Sensor I believe...And the Dizzy = Distributor
Good luck!
