Dead Cylinder in my J30
Discuss topics related to the VG and VE series engines.
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
My 1993 Infiniti J30 started running like crap two days after I put it up for sale. It felt like it was missing a cylinder, so I started unplugging each coil pack and found out which cylinder is not firing. So I first changed the spark plugs, and that cylinder is still not firing. So I then switched around coil packs and the same cylinder is not firing. Then I OHM-tested the injectors, and they are all in spec. So now I am lost. Its not the spark plug, its not the coil pack, and the injector tested good, what else could make a cylinder not fire? Please don't tell me it is something internal, lol.
Q45tech
Are you saying the coil is not getting the pulse from ecu or have you not actually checked for a spark extending coil out and a plug externally.
Each coil and injector has a separate driver transistor in ecu that switches ground on and off.
jwilliams050
Car: 1993 infinite j30t
did you ever figure out your problem? I AM HAVING THE EXACT SAME PROBLEM! I ended up buying an ignition module off ebay. And still no fix. HELP!!
Return to “VG30 / VE30 Forum”
