Thanks for the reply and info.Destrto wrote: ↑Tue Dec 12, 2017 10:25 pmI am having a similar issue as you are, currently with my 90 NA.
Just a couple things I have come across during my testing. Have you checked for any vacuum leaks or exhaust leaks? I was able to find an exhaust leak on mine from the EGR ports on the plenum. It never had an issue during the summer, when everything was always warm. Idled fine, never heard a miss. But now that it's gotten cold and all the old gaskets have shrunken up, the EGR plenum gaskets are leaking. Now, I'm still only assuming that's what my misfiring is being caused by, because I've done all the same testing as you have and everything came back within spec.
Well, I was wondering that myself and there is a way to test the injector while in the car. Using a device generically known as an injector pulse tester, you can run an injector with the engine off after the system has been pressurized. I'm satisfied that with the pressure being static, the location of a pressure gauge just after the fuel filter will give an accurate enough result.
I agree. The thing that throws me off is that you can hear the injector firing (clicking) with the stethoscope when the car is running and it really sounds like all the rest. In any case, the injector pulse test should let me about the function of that injector. Should get the testing device early next week
Thanks for the information regarding the effects of a vacuum leak on a given cylinder's performance. I'll keep looking into that as an issue as I work to verify the operation of the injector.amc49 wrote: ↑Sat Dec 16, 2017 8:59 pmI assure you that a vacuum leak if located right can kill one cylinder without any apparent affect on the others, it depends on the location, like a single runner well down it, the backflow to get to other cylinders being enough that time affects the others not getting the leak affect. Haven't seen it specifically on these but on other cars yes absolutely. The true sharing of the leak with other cylinders is based on how close to a mixing plenum the leak is. Very possible on two piece intakes where the join is in pure runners only, one runner faults a common gasket right in that one runner and there you have it. The others may never see it.
As well, the overall compression not given other than approved of and if anywhere down around 100 psi the engine not to mention the cylinder is dead. A whopping lot of people think compression is fine until you nudge them for the numbers and then that all changes. Plug color though says compression is OK.
That's great info, never knew about that specific vac leak info so thanks for sharing!amc49 wrote: ↑Sat Dec 16, 2017 8:59 pmI assure you that a vacuum leak if located right can kill one cylinder without any apparent affect on the others, it depends on the location, like a single runner well down it, the backflow to get to other cylinders being enough that time affects the others not getting the leak affect. Haven't seen it specifically on these but on other cars yes absolutely. The true sharing of the leak with other cylinders is based on how close to a mixing plenum the leak is. Very possible on two piece intakes where the join is in pure runners only, one runner faults a common gasket right in that one runner and there you have it. The others may never see it.
