mikey719 wrote:Alright, well my N/A started to miss slightly at idle about a month ago, not horrible, but annoying, i noticed the spark looked a little weak, so i replaced the coil pack and the miss continued, did the normal stuff, cleaned maf, ohm tested the injectors and all that fun stuff, but found no problems. Today I was driving to my friends house to have him look at it, and that cylinder started cutting out, then completely stopped firing all together. I replaced the plug, swapped coil packs, tested injector (12.6) and its still completely dead. The old plug looks fine, no build up, nothing out of the ordinary. Another thing that may help, is when i first start it, it will fire for maybe 5 seconds before it stops. I pulled the radiator cap, no bubbles, the cylinders next to it are all firing perfect, so that makes me doubt head gasket. Usually when i've had similar problems, I would get a strong smell from the unburnt fuel, but i noticed theres no smell, and the plug didnt seem wet when i took it out. I spun the CAS and the injector clicked but I'm wondering if they can get clogged to the point where they can kill a cylinder, and still test out? Any help would be appriciated, this is my DD and need to get back and forth to work!
After you do a compression test, re-look at that injector.
Im not sure if you have the newer or older style injector, but I had an interesting thing happen to me with a dead cylinder. After I got to Denver, my car started to get a miss. Before I moved I bought newer style injectors and the car ran great on the drive here. Well when I started to miss, I assumed injector. Tested the injector and it tested fine, clicked, everything. So I just passed that up, did a compression test, leak down, boost leak(which I found some leaks), every test I could think of. Still had a miss, so one day after ready to just give up on it, I decided to swap injectors, the miss followed. So I sent back the injector to ConceptZ, he calls me and say it flows fine and test good. So I told him my scenario, he sent me a new injector, everything has been good since.
It could be worth a shot if your compression comes out good or not. I just about sold the car cause my first three readings on the test had shown the compression was bad, but in all the cylinders, not just the one. So I knew something was up, after I got the injector fixed, retested the compression, a couple more times, all shown comp at 155. It was worth the extra work.
