Look at an exploded view of the clutch system and you'll see a "dead" clutch pedal can be hydraulic OR mechanical. You're right it's probably not transmission related, though.irocknrol2 wrote:Since you say you have a dead pedal, that means the fault lies in the hydraulic system an not the transmission.
FYI I used a steel braided line from my master cylinder to my slave cylinder and got rid of my damper, rubber line and hard lines.3 bleeds and it was bled! Like I said before if you need any help let me kow im in Concord, NC about 10 mins from Concord Mills [email protected]240spectre wrote:Yeah im probalbly going to bypass the dampener with a new clutch line. ive talked to alot people about it, and thats what they all say. ive done everything else. I appreisiate all the help.
