Steve, I have this exact problem right now. My car has sat in the garage for the last couple months and now the battery is dead. I tried to get into my car yesterday and I couldn't. I used the valet key inside the key fob and it does not work. When you put it in the key slot, there is no mechanical tension when trying to unlock it. Only the spring-loaded tension as if it is already unlocked.SteveTheTech wrote:There is a mechanical key inside each iKey remote. This should unlock the drivers door when the remote battery is dead or the cars battery is discharged to the point where the proximity sensors are not powered. If you press the remote or request switch and nothing happens.
As for getting locked in the car that would not be possible both inside and outside locks have aircraft grade cable connected to the lock mechanism.
Lock mechanisms have gone bad but they are fairly rare since 05 or so, but that has nothing to do with the battery.
C6 Vettes have electronic buttons that act as lock openers, apparently they can cause problems...
Well I called roadside assistance and they came out and unlocked it for me and gave me a jump. But after I let the car run for awhile and charge up the battery, I decided to try the key again, while it had power. The mechanical key doesn't do anything.SteveTheTech wrote:![]()
So if you turn the lock mechanically nothing happens?
Pm or text me if you need to.
There is a TSB (for 08 only) that might apply to your situation exactly, but it is VIN specific.
What's up with the mechanical keys though????
ITB10-010b, Take your car to dealer and they will replace battery.EZcheese15 wrote:Well I called roadside assistance and they came out and unlocked it for me and gave me a jump. But after I let the car run for awhile and charge up the battery, I decided to try the key again, while it had power. The mechanical key doesn't do anything.SteveTheTech wrote:![]()
What does the TSB say? VIN is JNKCV64E58M113775
See if you have blown fuse- ?08G37 wrote:Can someone please help? I am clueless about cars. I recently bought an 08 G37 Coupe. I was inflating the tires, because my low tire pressure light came on, and i killed my battery (I only did 1 side, so the battery sucks). Anyway, I tried to jump it with a booster pack - wouldn't work, but the car would turn over. I tried several evenings, but nothing. After the attempt last night, the light on the push start button indicator "Lock" wouldn't even light up. Nothing in the car will light up when I open the door, etc. It wouldn't start before, but now it's totally gone and wont even turn over. I bought a new 750 amp booster last night and tried it, and my g still won't do anything or even light up when I hook it to the battery.
Is this now more than a battery issue and if so, what could it be and what caused it? Can I simply replace the battery, or will this require a dealer visit? The nearest dealer is 2.5 hours away, so any help would be appreciated. Thanks so much!
Did you check the fuse box by the battery (has relays also) and by rest pedal in driver side?08G37 wrote:My dad looked, but he didn't seem to think there was a blown fuse after he pulled off the cover of the fuse box. Admittedly though, this car is a bit more high tech than he's probably used to.
Bulletin ITB10-010B. It's for 2008-2009 G37 coupes is applicable to your car which is still under warranty so dealer should replace the battery (may prorate) and fix the issue- what ever it is. Good Luck.08G37 wrote:I found another post with this bulletin - Bulletin ITB10-010B. It's for 2008-2009 G37 coupes. I think I'll mention that to the dealer. Maybe the tow in will be covered under warranty for this....
http://www.infinitig37.com/TSB/1ST34.pdf
If leaving it in ACC mode is what killed the battery, you had to have had it there for quite some time. The 5 or 10 minutes it takes to power a compressor to fill up your tires isn't nearly long enough to drain the battery.08G37 wrote:EZ, I had an air compressor plugged into the cigarette lighter, turned to I think ACC mode (radio on, but engine off), which drained the battery.
I just tried the key fob in the key fob insert in the car, but no luck.
The lights DID come on when I was trying to jump it earlier. However, after last night, NO lights are coming on at all in the car. I think something happened when I was trying to jump it yet again with the 400 amp booster, but I don't know what (this was prior to me getting the more powerful 750 amp booster, which maybe I should have done in the first place. The more powerful booster has yet to do anything as attaching it to the car now results in absolutely nothing, no lights, nada, the ignition light isn't even on).![]()
I have a friend who said he had a voltometer and could check the battery for me. I would also like to call the dealership to see what they say or if they have any suggestions.
Will keep you all posted. Thanks again!
audtatious wrote:I had someone state they used a trickle charger on the battery connectors while swapping the battery in order to keep a charge on the system and that kept them from having to deal with the power window issue.
I had the same problem replacing my battery and the first time doing the reset would not work. I disconnected and reconnected the battery and did the reset again and it worked. Quite annoying.
What email?Iaudtatious wrote:Was that you that sent me a email?
Someone had sent me an email at infinitig37.com concerning use of a trickle charger for my battery replacement how-to so I added it to the directions.cmesurf wrote:What email?Iaudtatious wrote:Was that you that sent me a email?
