Dead Battery !!
240Rider
So I hooked up some remote control fog lights on my 92 240sx a couple of days ago, I followed the instructions exactly and grounded the grounding wires to some bolts on the frame, then I connected the red wire to the positive terminal on my battery as indicated in the instructions. The lights worked fine, but the next day my recently purchased Interstate Battery was dead. Could I buy a smaller battery and place it somewhere in the engine bay to hook up the foglights and alarm. Or did I ground the wires wrong. Any help or advice is helpful, Thanks.
ninjak84
Car: S13, Z32, Titan
It sounds like you may have done something wrong with the wires.I would check those first.My battery is still stock, but I have a massive system inside, a top of the line alarm, and a Playstation with LCD screen. I figure if MY battery isn't dying, then your's shouldn't be either :D
240Rider
Did you hook those up directly to the positive battery terminal? and where did you ground the wires? Thanks
