Kendahl »
https://forums.nicoclub.com/kendahl-u69307.html
Sun Apr 04, 2010 1:31 pm
Some people have reported their original batteries dying in as little as three years. One symptom of a failing battery is that it seems to be fine immediately after recharging but doesn't hold a charge very long. The definitive test is to apply a heavy load. A battery that performs poorly is on its last legs and should be replaced.
Since you don't seem to be getting any satisfaction from the dealer, consider taking the car to an auto parts store or to a well recommended independent shop. They can perform the test and, if appropriate, sell you a new battery and install it. Consumer Reports found that some brands of batteries are better than others. Interstate was one of the good brands.
Another possibility is corrosion between a battery terminal and the connector. The battery may be fine, but the current can't get through the corrosion. Since your car starts fine after you get it to the dealer, I doubt this is your problem.
A third possibility is that you have let the car sit too long without being driven. Even when turned off, modern cars impose a small, but significant, drain on the battery. You can stop this by removing a battery cable but then you lose all memory settings. Like Telcoman, I have found that you can let the car go for a month without driving it. Two months is too long. If you park your car during the winter, your options are to disconnect the battery and lose the memory settings, put the car on a battery maintainer (which isn't the same as a charger), or put the car on a charger for two or three hours every month.
