AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Sun Apr 17, 2016 10:47 pm
Grab a flashlight and locate the primary hood latch, the hook. Should be somewhat accessible through the grill. You may have to go at it from underneath the car. You may have to fabricate a tool, but if you can carefully manipulate the primary latch, it'll release.
Have someone pull the release while you're under there looking. That'll tell you a lot.
Once you do get it open, lube the latch and hinges (as well as the release cable inside its casing) with silicone spray lube and work it up and down.
