BINGO!Skibane wrote:Less horsepower from a gallon of gas = more throttle required to provide the same amount of acceleration = lower fuel economy = zero net reduction in fuel cost...
That's already known, but like I said I don't care for the additional horsepower because acceleration is not what I'm after (considering I already have a Q to serve that purpose). There's no need to spend premium on two vehicles when the Q is already getting pampered. I'm more interested on the technical side of the equation: what separates the Armada from the QX56 in terms of modification to make the difference in horsepower and if there's any way to detune the QX engine to run regular? Despite what is being said about running regular, I strongly believe prolong use of regular gas in a engine engineered for premium will result in direct/indirect damages and/or shorten engine life. I noticed that the Armada and the QX56 gets the same MPG, so how is this possible? What can be done to the QX56 to make it run regular without suffering potential damages down the road?Skibane wrote:Less horsepower from a gallon of gas = more throttle required to provide the same amount of acceleration = lower fuel economy = zero net reduction in fuel cost...
It's not just a matter of acceleration.SFBayQ45 wrote:That's already known, but like I said I don't care for the additional horsepower because acceleration is not what I'm after
agreed totally. thanks andy.bullittandy wrote:I'm sympathetic to the fact that noone is answering your question.
I'm also in disagreement that running 87 will damage the engine. Unless there are actual mechanical changes between the Nissan and Infiniti engines then the only thing that is different is the timing and fuel and fuel is likely correlated with the timing. Octane requirements are very conservative because of all the gas/load variables across owners, geopgraphy.
Less octane, engine pings, K/S "hear it," less timing, no damage. Hell, its not even a certainty that the engine will ping on 87. There's alot of experimentation with timing and octane on 5.0 Mustangs. The factory timing is 8 degrees BTDC and an easy way to get some H/P is to bump the timing. Some guys run 12 degrees on 91 octane, some 14 and some 15, ping free, every engine's different. But I could be wrong....
I see where you're coming from in terms of your disagreement with regards to 87 not causing any damage, so you could take that risk but I'd rather play it safe. Everyone has his own interpretation.bullittandy wrote:I'm also in disagreement that running 87 will damage the engine. Unless there are actual mechanical changes between the Nissan and Infiniti engines then the only thing that is different is the timing and fuel and fuel is likely correlated with the timing. Octane requirements are very conservative because of all the gas/load variables across owners, geopgraphy.
Now we are into serious degradation of performance. First we'll lower the flash point, then we'll replace fuel with water!dsagers wrote:Another alternative is water injection.
