DE swap or DE head on E Block?
Drftwhor
Car: 90 s13
Hey Ive got a 90 240.. its runnin off of the SOHC i want to either swap a DE motor or put a DE head on a E Block.. I was just wonderin which one was easiest and what was more reliable.. and what are the processes to complete both of these projects.. hit me up with some info so i can find out which is the best to use
JeromeS13
Car: 2008 Subaru Impreza STI
First, welcome to the boards. Second, I'm sure the overall engine swap would be easier than messing with removing and installing the head on the different block. Third, search for the process.
91RMKS13
Car: 1992 240sx
The motors are cheap enough. Buy a KA24DE and keep the KA24E as a spare.
s14sleepyeyez
Car: 2003 Nissan 350Z
yeah I would say do the de swap, cheaper i believe so.
cdlong
Car: '95 240sx
full DE is cheaper and easier but a DE head on an E block will give you an 11:1 compression ratio giving you more power. there is a write up around here somewhere on how to do it.
with no other mods it should give you near 170 crank hp. with the right mods and tuning, you could crank it up to maybe 200 crank hp.
BIGT94z
thats whats up 200 chp on an ka-e
91RMKS13
Car: 1992 240sx
After the head swap it would be a KA-DE not a KA-E.
stevespeed
Car: RB-Swapped S13, FTW
Not to mention that if you look hard enough and wait you can get a KA24DE for nothing... it may not be in the best shape but hey its free.
nsmoracr
Car: '90 240SX
I talked to JWT on this same topic because I have an E, and the said that unless you are REALLY ATTACHED to the E block, just do an engine swap. It's possible to swap the heads (head bolts will match) but there are a couple parts that need to be machined to fit (It was awile ago when I asked...so I dont remember what parts he said exactly) So your best bet is what everyone has told you so far here, and thats just swap the whole engine.
