slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Mon Oct 18, 2004 5:11 am
Hi, I bought a very clean, smooth running KA with ~120k on it several months back. Since then I'v torn it down to assembled block(meaning everything is off, but crank/rods/pistons are still in). I had planned to have it fully checked/machined and install forgies. Long story short I'm broke, eager to drive my 240, and would like to just run stock for a while(going to pick up another block to build up after I get 'er running)
My question is this - can I get away with simply re-assembling the motor? Of course I plan to replace critical things external to the block, like pumps, timing components, etc, but I don't want to go all out with machine work(on this block). The block has set now for ~6months, without oil. My dad looked at the crank bearings when I got it, and said that they looked OK for an engine with that mileage. Should I bother sizing bearings? I plan to install new seals BTW.
From the information I was given from the previous owner, the eng. never burned or leaked any fluids. I have not turned the crank over since the oil has drained - however I did move a piston when checking the mains myself. Also there are bits of broken-up carbon on top the pistons - do I need to worry about scoring the walls?
Thanks! I'll try to be more verbose later this afternoon.-Jamie
