DE spark plug fit SR?
cvex
I have a set of NGK Iridium for the KA24DE , as pose side by side the DE is a tad bit longer(1/8") than the SR plugs. Will the extra length bottom out on the piston? How much clearance is the piston to head, anyone know?
ill_sil
Car: 91 coupe
shouldnt you buy sr20de plugs and gap them right, correct me if im wrong i think the gap is suposed to be .28
cvex
I know I should buy for the SR but i was just wondering if I can use these instead of throwing it away
s13sr20chris
NOOOOOO
1/8 of an inch is a mile when you are talking spark plugs.
you only want a bkr6e or a bkr7e. oh, or the platinum/iridium version of that same plug.
