De-powering a S-13 rack
gknracer
Car: 1991 240SX
Has anyone ever de-powered the rack and pinion unit for a S-13?
Goldeneagle
Car: 1992 240sx Coupe
Cut the powersteering belt.
You will have the most steering effort at low speeds such as turning corners or moving into a parking spot.
gknracer
Car: 1991 240SX
The power steering pump has already been removed. It seems to me that what I would have to do is to connect the inlet line to the exhaust line so that any fluid movement within the rack just goes from one side of the seal to the other freely.
Goldeneagle
You are correct. Loop the inlet and outlet lines.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Why would you do this?
Goldeneagle
Sentientbydesign wrote:Why would you do this?
Because he can and he wants to.
gknracer
Car: 1991 240SX
Actually, I am building a Locost and using the Nissan drivetrain. A locost is a replica of a 1959 Lotus 7. At only 1250 lbs I don't need (or want) power steering. Right now just deciding if I want to use the original rack or if I want to use something else. Thanks for the info though.
