Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Thu Mar 08, 2007 6:10 pm
Hmmm, just for craps and giggles. Start the car and let it warm up to normal operating temps, if it can. Then, take a can of CARB cleaner or Throttle Body Cleaner and spray down the intake manifold gasket (Intake manfold to head gasket) from the top of the engine. Concentrate on one area at a time. Please note if there are ANY changes in the idle at all when you do this.
If you spray down the intake manfold gasket and the idle changes, then you have an intake manifold gasket leak and it will have to be replaced. If there is NO change in idle when you are spraying, then it is obviously something else. Try this first, and check back.....
