C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Dec 04, 2003 5:39 pm
Why would you want shorter rods? Then you'ld have to have pistons with a low wrist pin location. The stroke does not change by changing the rod length. Too short a rod, and the piston may pop out inside the block.
As far as revving a KA to 8000, the stock motor will not be able to handle it. Most KA race motor builders say it starts to vibrate excessively at about 7500 RPM. The harmonics are just not suited for revving past this. You can try, but you'll probably spend a lot of money trying. Even the NASPORT KA's that can rev this high are not built with long term reliability in mind. 7000 RPM is plenty to work with. With the right cam you cam move the peak torque to a higher RPM, keep drivability and reliability, and better yet, with a well matched turbo, you can make some serious power.
