DE DET Part Interchangibility
score
Does any one know if the valve spring keepers and valve oil seals from a DE will work on a DET? Thanks in advance.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
The valve keepers will work,but the valve stem seals wont.
180fan
Car: 89 fastback
check the part list sticky at the top of the RWD SR specific page. s13srchris found the compatabilities with the usdm parts, I found the part numbers, and from what I reckon, we've both verified the fit.
score
So they will both work?
For valve oil seals I pulled:Intake valve oil seal - 13207-D4201 and Exhaust valve oil seal - 13207-2B500
What about keepers?
180fan
Car: 89 fastback
keepers? you mean retainers for the valve springs? Dunno the part numbers, but I got a set of crower retainers that were probably built for the DE's intially but can be used on the DET.
score
I mean the little half circle things that sit on the valve's keeper grooves. Theyre to prevent the valve spring from shooting off the valve.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I forgot which side had 7mm stems. The 6mm side can use the SR20DE stuff. The 7mm side will need a bigger valve seal (KA24DE) and keepers (I think KA24DE also). The USDM SR20DE have all 6mm.
SpeedRacer1
Car: 1990 240SX, G35
JDM S13 SR20DET Part numbers...13210-D4200 Collet-Valve Spring13209-53J00 Retainer-Valve Spring13203-53J00 Valve Spring, Outer13205-53J00 Seat-Valve Spring, Outer13207-84A00 Intake Oil Seal Jan91+13207-D4201 Intake Oil Seal Jan91+13207-53F00 Exhaust Oil Seal Aug96+13207-D0111 Exhaust Oil Seal Jan91+13201-1E700 Intake Valve Jan94-Aug9613201-1E710 Intake Valve Aug96+13201-53J00 Intake Valve Jan91-Jan9413202-53J01 Exhaust Valve Jan91-Feb9613202-53J02 Exhaust Valve Feb96+
USDM B13 SR20DE Part numbers...13210-D4200 Collet-Valve Spring13209-53J00 Retainer-Valve Spring13203-53J00 Valve Spring, Outer13205-53J00 Seat-Valve Spring, Outer13207-84A00 Exhaust/Intake Oil Seal 13207-D4201 Exhaust/Intake Oil Seal13201-53J00 Intake Valve 13202-64Y00 Exhaust Valve
180fan
Car: 89 fastback
ah ok. Not sure if the DE's will fit the DET's, but I figure the retainers are the same, so probably the keepers as well. I do have a spare set of keepers if you need those from a DET, but from what it looks like, they're all the same.
score
Sweet. If you have DET keepers, Ill take 'em. Shoot me an email and we'll work something out. [email protected]
180fan
Car: 89 fastback
you got mail
