deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Fri May 05, 2006 9:41 pm
May be the same tune, but I am not sure.
Get some A/F logs on your current setup and go from there. Make sure that when you do, you have just removed your battery cable and the ecu is free of codes throughout the run(s), especially any knock code.
Timing is where you are going to pick up the most gains. You can go with a general map modification that will provide good initial results, but realistically the timing should be perfected over a period of time as you continue to modify and change your engine. Or as always, by monitoring torque output on a dyno in relation to timing advance with detonation detection, once you are satisfied with your engine configuration.
You have california model car? What are the numbers off of your ecu lid?
