<sigh>... ok, look, this isn't going to turn into a pissing match, but I will post in my defense...
NISTECH wrote:it takes you one month to figure out that your distributor cap is on wrong? That was the very first thing NISTECH said to check!
I checked the cap man, it was one of the first things I reported back on. Not made in Italy, no carbon tracking. I even got a second visual opinion from my co-worker. I *knew* it was suspect, because of the excessive dust inside, and white arc-markings. Beyond that, there was nothing I could do to further 'check' it besides replacing it. Yes it's my fault for not realizing the rotor was not on all the way *then*, but the excessive arcing didn't make it apparent(untill a fresh cap/rotor were on) that it was not on all the way. Yes it, took me roughly a month for my cap/rotor to get in: ordered on the 10th or so and some other backordered items held the entire order up.
Obviously there were some discrepencies over the O2 sensor voltage. I was told the dataloggin values were in mV. This was from the guy who wrote the software. You and NISTECH(later) told me 100 on the graph=1V on the sensor. I wouldn't have asked twice had I remembered your post in the other thread.
Magnes wrote:1- Your reported symptoms (cold-start bogging).
Re-read my posts, I corrected myself and said it was cold-CAR start, not cold-engine. Before the new cap/rotor I could remote start for 15-20mins and it would still do it. I have not disabled the EGR since the new cap/rotor, and this my next thing to do. It didn't help before, I don't think it's going to help now.
Magnes wrote:3- The data stream (the ECU is shown to be sending the wrong signal to the EGR control solenoid. This is not a matter of opinion).
Again, I responded directly to you in this thread about this. The 'numbers' on the graphs are NOT related to the output signal voltage!!
slipnfall wrote:The CONSULT data I receive from my software reports EGR as ON or OFF. To translate that to a graph, I represent ON with 30, and ONwith a significantly lower value. This just makes viewing when it switches on the graph easier.
Magnes wrote:where exactly is your post where you claim you pulled the EGR vacuum signal?
Four or so posts up.
So anyways, I agree and think the EGR is still somewhat suspect. As you and Chris said in the first page, lack of EGR won't cause bucking, but excess will. Replacing the cap/rotor seemed to cure the warm-engine(and highway speed) symptoms, but not cold-engine/low speed. It's obvious the new/proper install of the cap and rotor illeviated some symptoms, but didn't cure the problem. Tomorrow morning I'm going to start-out with the engine cold, if it starts acting up, I'm going to stop, pull the EGR control line and see if that fixes it. It didn't before, so again I don't think it will this time.
Listen, no hard feelings on my end, I just couldn't help but feel attacked...
It's late, I'm out for the night.
