DDWRT scripts
Forum dedicated to computer hardware and software, mobile phones and electronic gadgets.
PoorManQ45
who's running ddwrt, and what scripts are you running?
Here are the two i'm using:
This one acts as a web filter. It blocks connections to every website on this list http://www.mvps.org/winhelp2002/hosts.txt
No matter what OS you're using it'll block traffic to those sites
Startup ScriptQuote »logger WAN UP Script Executingsleep 5test -s /tmp/dlhostsif [ $? == 1 ] ; then echo -e "#!/bin/sh\nwget -O - http://www.mvps.org/winhelp2002/hosts.txt | grep 127.0.0.1 | sed -e '2,\$s/127.0.0.1/0.0.0.0/g' -e 's/[[:space:]]*#.*$//' > /etc/hosts\nlogger DOWNLOADED http://www.mvps.org/winhelp2002/hosts.txt\nkillall -1 dnsmasq" > /tmp/dlhosts chmod 777 /tmp/dlhosts /tmp/dlhostsfiecho "45 23 * * 5 root /tmp/dlhosts" >> /tmp/crontab[/quote]This one basically tells the router to reject all incoming unsolicited requests for information. Or rather, it just drops them, so the requester doesn't even know it's there.
Firewall ScriptQuote »#!/bin/sh
# # Enjoy your enhanced security,#
echo 1 > /proc/sys/net/ipv4/icmp_echo_ignore_allecho 1 > /proc/sys/net/ipv4/icmp_echo_ignore_broadcastsecho 1 > /proc/sys/net/ipv4/ip_forward
# the following two parametes will break at least emule and are way too low to make sense.#echo 1024 > /proc/sys/net/ipv4/ipfrag_high_thresh#echo 512 > /proc/sys/net/ipv4/ipfrag_low_thresh echo 64000 > /proc/sys/net/ipv4/ipfrag_high_threshecho 48000 > /proc/sys/net/ipv4/ipfrag_low_thresh #
echo 10 > /proc/sys/net/ipv4/ipfrag_time echo 5 > /proc/sys/net/ipv4/icmp_ratelimitecho 1 > /proc/sys/net/ipv4/tcp_syncookiesecho 0 > /proc/sys/net/ipv4/conf/eth1/accept_source_routeecho 0 > /proc/sys/net/ipv4/conf/eth1/accept_redirects echo 1 > /proc/sys/net/ipv4/conf/eth1/log_martians echo 10 > /proc/sys/net/ipv4/neigh/eth1/locktimeecho 0 > /proc/sys/net/ipv4/conf/eth1/proxy_arpecho 50 > /proc/sys/net/ipv4/neigh/eth1/gc_stale_time
## The following entries secure the last bit and provide a# moderate protection against man-in-the-middle attacks.#
echo 0 > /proc/sys/net/ipv4/conf/eth1/send_redirectsecho 0 > /proc/sys/net/ipv4/conf/eth1/secure_redirectsecho 1 > /proc/sys/net/ipv4/icmp_ignore_bogus_error_responsesecho 5 > /proc/sys/net/ipv4/igmp_max_membershipsecho 2 > /proc/sys/net/ipv4/igmp_max_msfecho 1024 > /proc/sys/net/ipv4/tcp_max_orphansecho 2 > /proc/sys/net/ipv4/tcp_syn_retriesecho 2 > /proc/sys/net/ipv4/tcp_synack_retriesecho 1 > /proc/sys/net/ipv4/tcp_abort_on_overflowecho 10 > /proc/sys/net/ipv4/tcp_fin_timeoutecho 0 > /proc/sys/net/ipv4/route/redirect_numberecho 1 > /proc/sys/net/ipv4/conf/all/rp_filterecho 1 > /proc/sys/net/ipv4/conf/eth1/rp_filterecho 1 > /proc/sys/net/ipv4/tcp_syncookiesecho 0 > /proc/sys/net/ipv4/conf/all/accept_source_routeecho 61 > /proc/sys/net/ipv4/ip_default_ttl
# DoS protection by tweaking the timeoutsecho "1800" > /proc/sys/net/ipv4/tcp_keepalive_timeecho "0" > /proc/sys/net/ipv4/tcp_window_scalingecho "0" > /proc/sys/net/ipv4/tcp_sack
# We pretend to be a Checkpoint firewall on Windows XPecho 4096 87380 4194304 >/proc/sys/net/ipv4/tcp_rmemecho 4096 87380 4194304 >/proc/sys/net/ipv4/tcp_wmem
# Check network overload (explicit congestion notification)echo 1 > /proc/sys/net/ipv4/tcp_ecn
# Change port range for outgoing trafficecho "30000 60000" > /proc/sys/net/ipv4/ip_local_port_range
# Change default queue size# Modified for DD-WRT because of missing proc entries
echo 4096 > /proc/sys/net/ipv4/ip_conntrack_max
# LED signal feedback when script endssleep 1gpio enable 3sleep 1gpio disable 3sleep 1gpio enable 3sleep 1gpio disable 2sleep 1gpio enable 2sleep 1gpio disable 2
# If you'd like to disable the web interface uncomment# the following line#killall httpd[/quote]
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Now running DDWRT.
I added some of your scripts but how do I delete them if needed?
PoorManQ45
Click on edit right underneath the script you want to delete. Then highlight everything in the box and delete it.
Then click save on the corresponding button. Firewall or startup
WOLFANATOR13
Car: s13 hatch, s13 vert, evo viii MR
im running ddwrt, but im running to to reprogram the router to be a repeater, and it connects to the strongest fastest wireless connection every 3 minutes.i live in philly where there are many unsecure wireless signals, and i "borrow" everyone elses internet, mainly from the business's across the street. been saving me money now for 2 years. ill get the auto script then.
WOLFANATOR13
running your scripts, but now when i runn the startup on, everytime i go to a web page all and any of them, i can a pop up window saying "alert" "the connection to the server was reset while the page was loading."
Modified by WOLFANATOR13 at 12:58 PM 4/23/2009
PoorManQ45
hahahah. That's funny.
I would only recommend running the second script. The first one connects to a nazi like blocking script
Return to “Computers / Electronics”
