DDM Tuning HID slim kit. Reverse polarity.
mainstang
Car: 2010 Nissan Rogue
Just thought I would post this as it might save someone else some time later. I just purchased the ddm slim HID kit and the polarity for the rogue is different then the prefabbed plug. You must pull the pins foward carefully but it will require some force. You can either plug the pin directly into the stock harness or you can press the little teeth down and pull the pins back through the plastic adapter and reverse the polarity and press them back down into the plug adapter.
Return to “Rogue Forum”
