Success! Both fogs are now working correctly! Turns out one had a slightly poor fitting connector and both indeed seemed to require a 'burn-in' period before they stopped flickering. Man, they ARE bright but so far no sign that they irritate oncoming drivers.
BlackNWhite wrote:Why do you have to take off the whole front bumper to switch out the fogs? It's really unnecessary.
You just need to remove a couple clips off the splash guard and viola, easy access to the fogs.
Because of where we have the components installed, it is easier to get at them with the nose off. And it only takes 5 minutes to remove/install it. To just get at the bulbs themselves, yes, no need to remove the whole front end.
