daytime running lights
canadian booster
Car: 1993 Nissan Z32 TT JDM
so i'm going to fail my inspection today because i don't have daytime running lights. i'm going to wire up the foglights to fix this problem, but where's the best place to wire them to so when i turn on the car the foglights automatically come on?
mrmoose
Car: 91 300zxtt
i would go with a relay running 12v from the batt, then have it to turn on when the ign turns on with the 12 accessory ign wire... or something like that
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
^ what he said
You can tie into any wire(s) that are switched and get 12v. So when the key is turned to on, the wire gets a full 12v, but when the key is off there's no power to it. I'm trying to think of the best place to splice into but I'm drawing a blank.
Anyone have ideas??
Xplisit
Car: '94 Z32 2+2 N/A, '90 Z32 2+2 N/A->TT
Check the ignition coil relay and see if you can use that.
canadian booster
i managed to get it wired up enough to pass inspection on that part *woot* almost road worthy again :)
mrmoose
Car: 91 300zxtt
Nice, what did you use? Just in case any other ppl are tyring to do the same, maybe do a write up with some pics!!! as daytime running lighrts get you a nice break on insureance!
canadian booster
an insurance break? nice! in canada you need daytime running lights or your vehicle isn't allowed on the road. sure i'll get some pics and do a little writeup thing
