GseaQ wrote:Unfortunately, what you want can't be done. I researched it every which way. The American and Canadian models, believe it or not, have different wiring harnesses. I imported a '95 Q and the only thing I could do was a simple relay hookup to the clearance/ marker lights. Even the aftermarket DRL modules require you to merge the individual headlight circuits into one - unless you install 2 DRL modules - 1 for each light.
This is an answer I gave somebody on IOM a few weeks ago. I studied the wiring diagrams for both the Canadian and USA 1995 cars side by side. The harnesses are totally different.
The '92 has only a DRL module behind the right headlight and the high beam is on at 60% or something whenever the engine is running. Check the schematics out. Maybe the earlier models have a jumpered plug in the harness behind the right headlight.
The '95 uses a DRL module behind the right headlight and a DRL cancel module behind the left headlight or in the engine bay. Presumably this is used to coordinate the lights with the park brake.
Glenn
