I've been having nothing but trouble for years with my Daytime Running Lights (DRL). About 4 years ago, they stopped working - instead of putting the high beams to 50% power (like they're supposed to), it put 1 high beam on high, and the other one didn't light at all. I didn't bother with a solution because the cure is to put the low beams on and all worked well.
Now, what's happening is suddenly my DRLs work fine, but when I put my low beams or high beams on, it refuses to light the driver's side bulb in high or low, and the high beam indicator in the dash lights up in both cases. The bulb is OK because both lights light in DRL mode and I replaced it twice.
I have the factory shop manual and it shows you how the module is wired in, and I know it's located at the kick panel, but what do I bypass to make my lights work without this troublesome piece of electrical hardware?
